I have an opportunity to purchase a 1968 intake casting number #3905393 . Is this a good choice out of the allowable intakes for the 350-290hp combo?
Thank you in advance!
IHRA STK 932 O/SA |
Liked 718 Times in 220 Posts
The 393 intake is a a 67 327/275 horse unit, also the Camaro 350/295 horse engine used it.The 68 intake ends in #803. That came on the 327/250,275,300 and 325 horse engine, and the Camaro 350/296 horse engine.If you're building a 68 car, that's the one you need unless there is a specified acceptible alternate intake manifold.I would hate to put money into parts I couldn't use, or worse, get tossed after erroneously using it.
Thanks for the reply Greg,
I did check The NHRA tech sheets and the 393 intake is acceptable for the 350 4 barrel engine in '68. I am curious if this is a better intake than the 803?
IHRA STK 932 O/SA |
Liked 71 Times in 23 Posts
There isn't any difference between the two .
I have ran both of them.
Monte Howard 3209 STK, 3208 SS |
The 67,68,and early 69 intakes were all functionally identical. Only issue is the legality of whichver one you choose. They all were created from the same foundry molds.
