Old 11-05-2010, 03:02 PM   #1
my69396
Liked 46 Times in 20 Posts
Default dp engines
Does anyone know if the engines in the dodges are available in anything but the dp cars? Does the horsepower come from there crate motors? Wouldn't it be easy for NHRA to check the hp by running the cars as delivered? That would give them a more realistic factor. Just my thoughts. Jerry
my69396 is offline   Reply With Quote
Old 11-05-2010, 04:18 PM   #2
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: dp engines
The dp is a race only, the factory dose not build them. Engines in the showroom cars are different.
Bob Pagano A/SA
Old 11-05-2010, 06:25 PM   #3
Jeff Teuton
Liked 325 Times in 50 Posts
You know, that ain't a bad idea. I happen to have all the motors complete. I might just run them just to see 'out the box'. I think the difference between a factory motor and a prepped stock eliminator motor is more than most people think. If you think about it, a 396/375 Chev now makes 575-600-more. Interesting.
Jeff Teuton 4022 STK
Old 11-05-2010, 06:32 PM   #4
Jared Jordan
Liked 539 Times in 120 Posts
Send a message via AIM to Jared Jordan
As much fun as that would be, I'd at MINIMUM take the pan off for an inspection first.
Don't want you to end up with nothing but a pile of DP parts! haha
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline   Reply With Quote
Old 11-05-2010, 09:05 PM   #5
Jeff Teuton
We would check bearings etc. Install the right oil filter on the hemi's etc. Just no change to the cam, heads, injectors, fuel rails. One of them has actually been dyno'ed (360) so I will just run that one. The others we will check. This won't happen overnight, but stay tuned.
Old 11-05-2010, 10:02 PM   #6
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Other than the fuel rails mine is still stock... I did change the rods but that won't effect them...
Mack Reeves
2377 STOCK & SUPER STOCK
