Old 11-03-2010, 07:24 PM   #1
Phillip marvetz
Phillip marvetz's Avatar
Default Thermoquad sealer?
I have a thermoquad with a leaky fuel well, What can I use to reseal it?
2009 V/SA Record Holder
Old 11-03-2010, 08:56 PM   #2
Tom Turner
Default Re: Thermoquad sealer?
We use JB Weld (the quick variety). Tape off the body and glass bead the well area, clean with denatured alky, glue up. 24 hr dry time. TT
Tom Turner is offline   Reply With Quote
Old 11-04-2010, 09:54 AM   #3
BlueOval Ralph
Banned
A product called Seal All we use it to seal gas tanks and Holley Floats
http://www.totalmotorcycle.com/revie...GlueReview.htm
Total Motorcycle Reviews
Seal-All Glue
Product: Seal-All Glue
Manufacturers Website: http://eclecticproducts.com/sealall/home.asp
Manufacturers Description: Seal-All, The all-purpose contact adhesive & sealant
Gas and Oil resistant
In a class of its own, “the repair kit in a tube” is not affected by gasoline, oil, alcohol, water and most solvents, making it ideal for automotive and garage repairs.
Seal-All dries fast without sacrificing strength. Dry speed is 2–3 minutes, with a 2–6 hour full cure time, making it perfect for in the garage, around the house or on the go.
PROPERTIES OF CURED MATERIAL
Hardness: 90A
Tensile strength: 7,250 lb./in.2 (ASTM D-412)
Elongation: 25% (ASTM D-412)
Chemical resistance: Excellent to water, oil, gasoline, alcohol, dilute acids, dilute bases
Service temperature
range: -40°F (-40°C) to 150°F (66°C)
Paint-over time: 8 hours
UV-resistance: To maximize UV resistance, paint over Seal-All
Product History: Eclectic Products, Inc. was founded in 1972 to market Shoe GOO, a rubber compound that doubled the life of shoe soles. Since then, in response to customer demand, the company has expanded its line of products to include adhesives, fillers, and other do-it-yourself products for home and commercial use. Eclectic Products is headquartered in Eugene, Oregon and has a manufacturing facility in Pineville, Louisiana. Since 1988, the company has been a wholly-owned subsidiary of The Willamette Valley Company.
Products
Eclectic Products makes a wide variety of specialty home improvement and industrial products.
Amazing GOOP Adhesives
Amazing GOOP Epoxies
Shoe GOO
Seal-All
Famowood
Painter's Nail Hole Filler
E-6000
WoodTex
Stores
Eclectic Products can be found in more than 35,000 stores throughout the United States, Canada, Mexico, and Asia. The following is a partial list of our retail outlets:
The Home Depot
Lowe's
Wal-Mart
Kmart
Menard's
Handy Hardware
Albertson's
Hobby Lobby
Do-It-Best
Target
Ace Hardware
Fred Meyer
Walgreen's
Tru-Serv
Canadian Tire
Michael's
JoAnn's
Suggested Uses: AUTO: Use for distributor caps, interior panels, radiators, gaskets, transmission carburetor floats, body and trunk leaks, battery cables and terminals, generators, tools and much more.
GARAGE/SPORTING: Use to repair and maintain oil pans, gasoline tanks, oil lines, golf club grips, fletching arrows, fishing rod tips and guides, tents, canoes, boats, outboard motors, fishing lures, woodworking, model kits and more.
HOME/CRAFT: Use to repair and maintain glass, china, crockery, leather, metal, porcelain, fiberglass, most plastics, ornaments, figurines, linoleum, oil cloth, furniture, knobs and drawer pulls, screens, tile, plumbing, gutters and much more.
Seal-All® adheres with superior strength to all substrates and materials except paper, cardboard and Styrofoam™. Always test a small area before full use.
Our First Hand Review: Seal-All, and is manufactured by Eclectic Products. It comes in different sizes and is quite clear when it comes out.
The distinguishing feature of this glue is its resistance to water, gasoline and oil, which makes it the ideal glue to keep on your motorboat or motorcycle.
It fixes gas tank cracks, seals tire punctures, and even works well on plastic and glass. It dries clear in about one hour.
We have used this glue on many different parts of our motorcycles, from carb boots, mirrors, plastic parts and wiring. It really does work well and will bond quite quickly (about 2 minutes of pressure).
Where is doesn't work all that well is on things like HDPE plastics (cracked bucket). It just doesn't have the holding power it should.
The only negative feature of this adhesive is its toxicity. It contains methyl ethyl ketone, which is dangerous and should only be used in small quantities with a good cross breeze.
Cost was very good for what the product is and does. We found it to be mcuh cheaper in price compared to other competing products. You also get a lot for your money, our tube was $5 and holds 60ml (2fl. oz.) that is a lot better than Crazy Glue.
Luckily, Seal-All can be found almost anywhere, which makes it an ideal buy.
How long does it take for Seal-All® to dry?
Seal-All® will hold in 2-3 minutes
Reaches full-cure in 2-6 hours.
What is the most unique feature of Seal-All® ?
Seal-All® is resistant to gasoline, oil, paint thinner, and most solvents. Seal-All® is also water resistant immediately upon application.
What are the directions for using Seal-All®?
To use unscrew cap and break seal with pin. Do not squeeze tube to force opening.
FOR BONDING: Apply thin coat of Seal-All® to both surfaces. Allow to set until tacky; press together firmly and allow to dry.
FOR GASOLINE LEAKS: Press small amount of Seal-All® directly to leak. Hold firmly for several minutes until it congeals. Allow first application to dry 5-10 minutes. Several coats of Seal-All® should be applied, allowing each coat to dry.
FOR PLUMBING LEAKS: On water lines, garden hoses, or any leak having pressure, it is advisable to tape over Seal-All. Another coat of Seal-All® may then be applied over tape.
FOR OIL & WATER LEAKS: Apply Seal-All® to clean, dry surface. Allow to dry.
WARNING: Wet Seal-All® may damage finished surfaces. Avoid such contact until Seal-All® is completely dry.
To ensure easy cap removal, apply thin coat of petroleum jelly to threads of tube before replacing cap.
Replace cap each time after using. Keep tightly closed when not in use.
Store in a warm place-jells when cool.
Overall: We are very happy with the Seal-All product. It does what it is made to do, resist gas and oil and provide a very good seal. We have tested it on carb boots and it worked great!
While Seal-All doesn't work 100% on everything, it sure does work on a a lot of different materials.
A great idea is to keep the small version with you in your emergency repair kit, it really works well.
Well recommend to buy and try.
BlueOval Ralph is offline   Reply With Quote
Old 11-04-2010, 12:35 PM   #4
R Hastings
Phillip, I'v used both seal all and J b weld in the past. So use whichever you have on hand.
Are you switching the wagon up to a V/8?
R Hastings is offline   Reply With Quote
Old 11-05-2010, 02:26 AM   #5
Phillip marvetz
Thank's for recommendation guy's. I'll try the Seal All since I have heard that the JB weld doesn't like some of the race fuels.
Randy, No the wagon will keep it's slant six for now. This carb is for my 71 340 combo Duster that my wife will pilot in E or F next year. She likes to go fast but I haven't given up on the wagon yet, Although I did kick a rod bearing out of it the one and only pass I made in it this year.
She was a good sport about going slow all year so I think she deserves a nice fast hot rod for next year. Now if I can only get the Hemi to run faster than a 340 I'll be a happy boy.
