Old 11-01-2010, 06:51 PM   #1
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Bio degradeable RV anti-freeze
Any down side to using RV anti-freeze for storing your race car in the winter?
I have been using the standard "green" anti-freeze, but it is so hard to dispose of in the spring when I dump it in preparation for another race season. My block is hard blocked, if that matters..... TIA
Old 11-01-2010, 07:57 PM   #2
Rick Bailey
Rick Bailey's Avatar
Liked 10 Times in 7 Posts
Talking Re: Bio degradeable RV anti-freeze
Bob,
I've been using rv antifreez ( the pink stuff) in my s/c car for over 10 yrs now, I use it year round. I have never had any cooling problems, no rust, ......cleans up well. I used to travel from the midwest (Illinois) to fla in feb. My blk is also filled.
Hope this helps
Rick
Rick Bailey 3439 SC
Rick Bailey is offline   Reply With Quote
Old 11-02-2010, 06:30 AM   #3
rallye bob
rallye bob's Avatar
Default Re: Bio degradeable RV anti-freeze
Will there be a problem if I don't get every last bit of water out before filling with the "pink stuff" as the drains on the sides of the block are useless after the hard block, fill?
I do pump as much of the water out as I can by running my electric w/pump and opening the drain on the radiator
I store the car in an un-heated, attached garage for a northern Illinois winter...
Old 11-02-2010, 10:27 AM   #4
Rick Bailey
Bob, my guess would be get it all.....even if you have to fill it with pink and run your pump to thin out the water, drain then refill. maybe twice.
Keep in mind, pink stuff is cheap, so wasting a little won't hurt. And to avoid all this work next year....just run it year round.
This subject came up on DDR too , you might give it a read too.
http://drr.infopop.cc/eve/forums/a/t...2/m/7727026095
Rick
Rick Bailey 3439 SC
Old 11-03-2010, 06:55 PM   #5
LittleBubba
we use windshield washer fluid. Less then $2 at wal-mart, good to -20 degrees, and you can dump it anywhere when your done
LittleBubba is offline   Reply With Quote
Old 11-03-2010, 09:13 PM   #6
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
I wonder if the achohol in WWF would affect rubber seals in the water pump ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
