Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 10-27-2010, 03:52 PM   #1
mike natoli
mike natoli's Avatar
Liked 51 Times in 16 Posts
Question Titanium Valve < Spring Pressures
Taking advantage of running titanium valves does anyone have data of Valve Spring pressure reduction?
mike natoli is offline   Reply With Quote
Old 10-28-2010, 04:29 PM   #2
mike natoli
Lightbulb Re: Titanium Valve < Spring Pressures
Does anyone know were I can post this question and get some discussion. I checked the Corvette LS7 titanium valve specifcations and they are running .331" lift with 1.8 rockers total lift .590" , 101 lbs. spring pressure @ 1.95" installed height 310 lbs. @ 1.37" open using roller hydraulic lifters. I have found on a flat tappet mechanical cam with 1.5 rockers with 2.08 intake steel valves that I need around 150 closed - 450 open to allow the valve to open and close without float to around 7200 - 8200 rpm. I guess I'm just going to do it and find out as usual.
Old 12-10-2010, 01:24 PM   #3
raceman14
Default Re: Titanium Valve < Spring Pressures
Mike,
Your question on valve springs, pretty much depends on the quality of the hydraulic roller lifter you are using and where it starts to lose ability to hold hydraulic pressure.
Most folks think once they are pumped up they stay that way but after many hours on the spin-tron, we learned they bleed pretty bad at high rpms. Most of the work was done for GM 604 Oval track crate engines but the theory applies to any hydraulic lifter.
I have some super nice PSI springs designed for the application along with matching roller hydraulics for .842 lifter bores & Chevy Tie bars. Set-up height is in the 1.850-2.050" / .600-.800" lift. This package is 125-150# on the seat depending on the set up height. This package is worth about 1000rpm and 15-20HP on a Stock 604. More cam and more head flow makes a greater difference.
It is a delicate balance kind like balancing a see-saw with the spring pressure on one end and the hydraulic lifter on the other. I can tell you that valvetrain stability is worth 10-20% RWHP increase on hydraulic lifter engine.
raceman14 is offline   Reply With Quote
Old 02-24-2012, 11:56 AM   #4
MontyF
Originally Posted by raceman14 View Post
Mike,
I have a few questions concerning what you found.
So according to your tests the issue is bleed down instead of pumping up?
Can this be avoided by limiting lifter plunger travel? I'd assume as the spring loses control of the valve train, so the lifter is unable to follow the cam, pump-up is still possible?
MontyF is offline   Reply With Quote
Old 03-05-2012, 12:42 PM   #5
James L Miller
Liked 25 Times in 16 Posts
You can calculate the change in spring RATE using the following formula:
w0=SQRT(k/m)
where w0 is the natural frequency of oscillation (valve float)
k=spring rate
m=mass of valve, part of the spring and retainer and lock.
http://en.wikipedia.org/wiki/Damping
Mopar 2 Ya!
