Old 10-26-2010, 05:04 PM   #1
Jason Oldfield
Jason Oldfield's Avatar
Liked 10 Times in 4 Posts
Send a message via AIM to Jason Oldfield Send a message via MSN to Jason Oldfield Send a message via Yahoo to Jason Oldfield
Default 2011 Rule Book Amendments
Can be found here: http://www.nhra.com/UserFiles/file/2...Amendments.pdf
Or, you can go to the main NHRA page and hunt for the tiny box that reads "Racer Updates" among all the distracting clutter, and click on the "Racer Updates" button. Why this wouldn't be on the main "COMPETITION" tab is beyond me (more logic).
Biggest change I can see is that starting Jan. 1, 2012 oil-retention devices (e.g. diapers or belly pans) will be required on all S/St entries, and beginning June 1, 2011 all roll-cage padding in S/G needs to meet SFI spec 45.1 where the driver's helmet could hit the roll cage (also for cars running 9.99 or quicker).
Oh, and for you guys with secondary braking systems, they're now going to be permitted as long as both are connected together and activate all braking systems on the car at once (i.e. you can't use the hand brake to only control the front brakes).
As a side note, did anybody know that the maximum burnout time is 5 seconds? That's a pretty long burnout, but I honestly didn't know there was ANY time limit...
Jason Oldfield
S/G & S/St 1838
Jason Oldfield is offline   Reply With Quote
Old 10-26-2010, 05:57 PM   #2
Duane Dagostino
Default Re: 2011 Rule Book Amendments
They still don't get the fact that on a dragster, 2 independant systems with 2 m/c's,and 2 sets of calipers is a safety plus....
Duane Dagostino 1821 S/C, S/G
Duane Dagostino is offline   Reply With Quote
Old 10-26-2010, 06:22 PM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 552 Times in 215 Posts
I am not going to remove the handle on my hand brake actuated set of brakes and I am also not going to connect both sets of calipers to work off one MC. NHRA Tech is completely wrong on this one and it's hard to believe they don't see the logic or safety factor in having two independent sets......It's my car and my life.....I will either race it as it is or stay home....
Rich Biebel
S/C 1479
Stock 147R
Old 10-26-2010, 06:37 PM   #4
lazrcng
lazrcng's Avatar
Well said, I absolutely agree.
lazrcng is offline   Reply With Quote
Old 10-26-2010, 07:22 PM   #5
Rick Bailey
Rick Bailey's Avatar
Liked 10 Times in 7 Posts
Ok we all know that NHRA says NO ! to the independant brake system... but I would like to hear their reason........maybe Rock could help here.
No I don't have a second system, but I think it could be wise....
Rick
Rick Bailey 3439 SC
Rick Bailey is offline   Reply With Quote
Old 10-27-2010, 01:16 AM   #6
Chris Williams
Chris Williams's Avatar
I think you guys are reading these rules wrong. The applicable sentence is
Originally Posted by NHRA 2011 Rule Book Amendments
Secondary braking systems are permitted as long as the hand brake and foot brake are connected such that any movement of either engages both master cylinders and all calipers.
Note the use of "both master cylinders and all calipers". That means systems with dual MCs and multiple calipers are fine. You just have to activate both with both the foot and hand brake. Seems OK to me??
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 10-27-2010, 07:06 AM   #7
Duane Dagostino
Chris...that would give you twice the brakes...the idea is to have 2 systems in case one fails...twice the brakes improves the chances of locking up if hit too hard...all of us who have this set-up would just like an explanation from NHRA as to why this such a problem. I feel they are making my car less safe!!
Old 10-27-2010, 08:19 AM   #8
BKSG1198
BKSG1198's Avatar
What happens if you do a burnout longer then 5 seconds?
Old 10-27-2010, 08:50 AM   #9
GaryGoFast
Talking Re: 2011 Rule Book Amendments
In order to move the classes along so Alcohol may have its alloted time added to offset oil cleanup, NHRA has decided to enforce it 5 second burnout policy, any person doing a burnout for more than 5 seconds will be forced to install a secondary timer to control this issue.
These NHRA approved devices can be purchased at our ....................................
Gary Federico
S/St, S/G 1814
GaryGoFast is offline   Reply With Quote
Old 10-27-2010, 12:28 PM   #10
Jason Oldfield
Roflmao! :d
Originally Posted by garygofast View Post
in order to move the classes along so alcohol may have its alloted time added to offset oil cleanup, nhra has decided to enforce it 5 second burnout policy, any person doing a burnout for more than 5 seconds will be forced to install a secondary timer to control this issue.
These nhra approved devices can be purchased at our ....................................
Jason Oldfield
S/G & S/St 1838
