Old 10-22-2010, 04:40 PM   #1
boostedf22c
boostedf22c's Avatar
Default (2) Weldon 2025-A Electric Fuel Pumps
The person I bought these from said they have never been run. They don't smell like gas, and appear new internally, but the bodies have a few knicks and scratches.
Performance Chart: http://www.weldonracing.com/~weldon/...5%20Series.pdf
Dimensional Drawing: http://www.weldonracing.com/~weldon/ul-pdfs/42-2025.pdf
Maximum HP: (-12 inlet and -10 outlet) 1400 hp Inj @ 14V EFI (700 hp on Methanol) & 1600 hp @ 14V Carb (800 hp on Methanol)
GPH/PSI Range: 140-180 GPH / 0-80 PSI
Features:
Self Priming
Pump may be mounted above fuel cell
vertical or horizontal mount
Breakaway coupling prevents pump/motor damage in the event of fuel contamination
All internal wear components are 100% metallic
No plastics or composite materials. Our internal pumping elements are made of high speed tool steel and bronze. This results in the longest lasting, highest quality, most durable pumps available.
Body machined from billet aluminum
For carbureted or injected engines
Provides Consistent Performance with no fall-off in flow
Precise fuel delivery
Blades self-compensating for wear
Compatible Fluids:
Gasoline
Diesel
Methanol
Ethanol
Nitromethane
All racing fuels
$750 new per pump
$1500 new for both
I'll take $450 each, or $800 for both shipped or picked up.
Here are a few pics
boostedf22c is offline   Reply With Quote
