Old 10-08-2010, 02:38 PM   #1
NORMAN BARNARD
Liked 2 Times in 2 Posts
Default Chevy 502 block for sale
Mark " 6 " big block chevy , 4 bolt main block , thick wall std bore , low deck block 9.8 is the deck height, NEVER had a rotating assembly installed in it. has cam bearings and brass freeze plugs installed. Depending on differnet bore and stroke (crank) it will go to 540 . I will also give with it the following extra parts
* new moroso #22162 - nitrated racing oil pump and shaft
* new reher-morrison rear main seal adapter (no machening required) run early 2 piece seal and crank
asking $ 1625.00 firm , i dont have a picture but can get one if anybody is interested as i have it put away and wrapped up. If interested please send me a message. Can pick it up or i can help with finding you some one locally to crate it up for you, buyer pays for all costs.
Thanks !
NORMAN BARNARD is offline   Reply With Quote
