Old 10-03-2010, 11:22 AM   #1
boostedf22c
boostedf22c's Avatar
Default Coan 7" Maximum Performance Steel Stator Convertor (~7000stall)
Brand new, never ran. Was going to use this with a powerglide setup but decided to go manual.
Coan part number COA-10600A - http://www.coanracing.com/Catalog.as...uctDetail=1072
Coan has it listed on their site for $1750, I will sell for $850 obo. GET A BRAND NEW CONVERTOR FOR OVER 1/2 OFF!!!!!
TX3015D
The T means it is a turbo spline.
The X means it is a steel stator... Good, stronger than an Alum.
The 30 means it is a 30 degree fin angle on the stator. Loose, high stall
15 is the Stator blade count. The more blades the higher the stall and more torque multiplication.
I think that no number between the 15 and the D means if it a full fin Stator that should be a hard hit leaving.
The D is the pump fin angle. A being full positive and E being full negative. C would be neutral fin angle.
Pics
boostedf22c is offline   Reply With Quote
