Old 10-01-2010, 09:40 AM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default 8 or 10"
I have to run a 9" slick. Is there advantage to using one wheel over another. I plan to run a 30" tire. Seems like an 8" wheel would allow more tire growth and be a little lighter. TH400, 4:88, 2800lb 70 Nova. Your thoughts are greatly appreciated.
Ron Gusack is offline   Reply With Quote
Old 10-01-2010, 10:15 AM   #2
Dion Hildebrandt
Dion Hildebrandt's Avatar
Default Re: 8 or 10"
10" rim will give you a better contact patch, stretching the sidewalls keeping the contact patch flater on the track
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 10-01-2010, 02:15 PM   #3
Run to Rund
Liked 54 Times in 27 Posts
I've tried both 8" and 10" with Hoosier 30x9 slicks. I tend to agree with both posts above. One caution: the sidewall will be about .3 to .4" wider on each side with the 10" wheel, so check your clearance!
Old 10-01-2010, 02:24 PM   #4
et7333
et7333's Avatar
x2
et7333 is offline   Reply With Quote
Old 10-01-2010, 02:58 PM   #5
10", especially if you use radials.
Old 10-01-2010, 03:12 PM   #6
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Me Too......................
Bob Bender 144 O/SA
