Old 09-30-2010, 07:57 AM   #1
gt_diesel
gt_diesel's Avatar
Default Top Sportsman - Dragster Trades
1994 Corvette
VFN Glass Nose
25.1e JBRC Chassis built in 2007
NHRA & IHRA Pro Certs
Pro Mod 4-link
JBRC 9" Rear w/4.30 Richmond Pro Gears
96" CM Wheelie Bar
Aldan Double Adjustable Shocks with Custom Valving
Steel Driveshaft Tunnel
Strage Struts
Aerospace Brakes
6 Gallon Fuel Cell
Autometer Gauges
2 Sets of Headers ( Tall Deck and Short Deck )
Motor Plates for BBC / Lenco & Glide
New Aluminum Radiator
Trans Cooler
10# Cold Fire System
Platinum Belts
Aluminum Seat
Stroud Dual Air Launcher Chutes
7-AL
MSD 3 Stage Retard
2 Stage Rev Limiter
Precision Air Shifter & CO2 System
Wired for 3 Stages of Nitrous
Bogart Front Wheels
Weld Rear Wheels with 34.5x17 Goodyears
Car weighs 2450 with Aluminum Head 632 & Glide
Trade for Top Dragster Roller of Equal Value.
Also available...
Reid Case Glide
1.80 Straight Cut Gears
Billet Clutches
Billet Shafts
Billet 9.5" Converter for Blown / Nitrous Application
632" BBC
12 Degree Raptor Heads with Nitrous Chambers & Ports
2.45 / 1.85 Titanium Valves / Springs / Retainers
Heads flow 560+ at .800
T&D Shaft Rocker System
.857 lift nitrous camshaft by Custom Cams
Custom Diamond Pistons @ 16:1
GRP Aluminum Rods
Lunati Billet Crankshaft
Big M Block
Pro Filer Intake with Two NX Foggers
Gemini Plate System
Custom Dominator 1500cfm +
Vaccum Pump
Custom Valve Covers
SFI Balancer
SFI Flywheel
Made 1100hp on Dyno with Single Carb on Motor Alone...
Ran 4.41 @ 163mph in 2800# Doorslammer with Glide on Plate & One Fogger...
Looking to trade roller for roller top dragter...
May trade turn key for turn key for the right ride... Blown or Nitrous but it must run easy 6's
mx278@metrocast.net
IHRA Top Sportsman 178X
Blown Alcohol Corvette
gt_diesel is offline   Reply With Quote
