Old 09-28-2010, 10:58 PM   #1
StockerRook
Default Bore Alignment Tool
Hey Everyone,
I had a quick question. We are about to clean up a LT1 block that i have for a stocker motor. Give it a minimum bore to clean the cylinder walls. I had heard something about a Bore alignment tool that uses the dowel pins on the back of the block. Does this ring a bell with anyone?
If so, is it necessary to use or am i being over-picky? Where could i find or borrow one. Any help would be appreciative. Thanks in advance.
Chris
StockerRook is offline   Reply With Quote
Old 09-29-2010, 08:00 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Bore Alignment Tool
Contact BHJ Called a Bore True. It corrects cylinder head location and bore centers.
references off the rear main. It does not square the decks. They have another fixture for that. Some blocks are off more than others. You might find the block you choose will have to take more than a min. cleanup bore to be corrected. I suggest "Not" buying pistons until you get a rough finish size on the bore, if you only have one block. I've had customers that had to re-buy pistons because of the block. I've had other customers go through a couple of blocks before getting one that will bore to their size. This tool is extremely helpful in getting the correct bore location in some of the GM bowtie blocks that have an extremely rough initial bore. (unfinished) I haven't seen one in a while, but have seen plenty in the past. I don't call it picky, being precise. Some of the old blocks are way off. It helps with valve pocket alignment, too.
Adger Smith (Former SS)
Old 09-29-2010, 09:30 AM   #3
StockerRook
Adger,
Ill contact them. Thanks for the help, I really appreciate it.
Old 09-29-2010, 01:39 PM   #4
Woodro Josey
Liked 3 Times in 1 Post
Chris, not trying to tend to your buissness but you best Sonic Test the block first before you bore it, you might be surprised at what you find! The LT1 has some very Thin spots
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 09-29-2010, 03:18 PM   #5
StockerRook
Woodro,
I will do that. Thanks for the heads up.
