Old 09-24-2010, 10:56 AM   #1
hutt1
Smile 1969 camaro TRADE FOR MOTORHOME ts,sq,sc,sg,et .. 6.0 certified chassis
1969 Z28 CAMARO TS,SG,SC OR SQ!!!!!!!!! 6.0 NHRA CERTIFICATION, CHROMEMOLY CHASSIS MARCH 2010,TOP SPORTSMAN CHROMEMOLLY DRIVE SHAFT TUNNEL,ALL NEW WITH ONLY 9 PASSES ON EVERYTHING... COMPLETE TURN KEY, 2430 #S WITH 200 POUND DRIVER... 520'S IN THE 1/8 ANDS 9.90 @155 SO FAR IN THE 1/4
CHASSIS
1969 CAMARO GEBHARDT/BILLY WEBBB RACE CARS CHROMEMOLY CHASSIS WITH STEEL ROOF AND QUARTERS, LEXAN WINDOWS,NEW PAINT, CURRENT 6.0 NHRA CHASSIS STICKER MARCH 2010,RJ SCOOP, FLAT HOOD,SIMPSON CAMLOCK BELTS EX 8 2012,CARBON TUBS AND SOME INTERIOR PANELS, NEW SUMMIT RACING 5 GAL ALUMINUM FUEL CELL, MAGNAFUEL 500 FUEL PUMP, # 10 LINE TO FRONT,BE COOL RADIATOR WITH SHROUD AND FAN,ALSO SET UP FOR PUMP TO BE IN RADIATOR, WE ARE NOT RUNNING IT THAT WAY NOW. SWAY BAR , WISHBONE LARGE 4 LINK BARS, AFCO REAR SHOCKS, STRANGE FRONT STRUTS WITH STRANGE BRAKES ALL NEW,NEW LAMB MASTER CYLINDER,NEW GARY JENNINGS RACE CARS WHEELIE BARS, 5# AIR BOTTLE, SIMPSON CHUTE, 16V TURBOSTART BATTERY,HOOKER COATED HEADERS, CARBON WING
REAR END
MW BILLET REAR END WITH STRANGE ULTRA LITE 40 SPLINE AXLES, STRANGE 40 SPLINE ULTRA CASE WITH 430 PRO GEARS. MARK WILLIAMS REAR DISC BRAKES, 15" WELD WHEELS BEAD LOCKS
TIRES
HOOSIER 24 FRONT AND HOOSIER 33*16*15 REAR TIRES 9 PASSES ON BOTH
TRANSMISSION
BTE TOP SPORTSMAN GLIDE, 180 STRT CUT GEARS, PRO TREE BRAKE,BTE CASE,BTE FLEX PLATE,BTE DEEP ALUMINUM PAN,9" BTE LARGE MOTOR T/S CONVERTER, TRANS COOLER WITH SHROUD AND FAN INFRON OF RADIATOR, TCI/ AND ELECTRIC SHIFTER. ALUMINUM DRIVESHAFT WITH MW YOKE
ENGINE
ALL ALUMINUM JEFF TAYLOR 540
DART ALUMINUM TALL DECK BLOCK, STINNETT SUPER CARB,QUICKFUEL REGULATOR, TEAM G INTAKE, DART 355 CNC PRO 1 HEADS, JESEL ROCKERS, JESEL BELT DRIVE, BULLET CAM, SHEET METAL VALVE COVERS, BRC BILLET CRANK,BRC PISTONS AND EAGLE RODS WITH 2000 SERIES BOLTS,MOROSO VAC PUMP, CHARLIES ALUMINUM OIL PAN,MSD BILLET DISTRIBUTOR,ATI BALANCER AND DRE DIAPER.......... 949 HP AT 7000 ON JEFFS DYNO..
ELECTRONICS
BIONDO MEGA 450 BOX, BIONDO/ONE STOP 4 HOLE AIR THROTTLE STOP, MSD 7AL3, MSD BLASTER COIL..
will trade FOR CLASS A DIESEL PUSHER . MUST BE NICE!!!!!!!! if you want call or txt 615-429-8895
scott
inscontractors@comcast.net
RACINGJUNK AD # 1981034
68,000.00 OR BEST OFFER
hutt1 is offline   Reply With Quote
