Old 09-21-2010, 06:04 PM   #1
Jim Bailey
Liked 584 Times in 94 Posts
Default 1963 Mopar Max Wedge Engine - Complete
Complete '63 Max Wedge Engine. NHRA/IHRA Legal Stocker engine - Shaul Carbs, Crossram, MSD, Don Little Heads, Comp. Cams, Schubeck, Manton, +.060 Ross, Manley, Isky, ATI. Mopar Perf. Fresh, ready to go, Dyno Sheets available. 10.20's everytime you step on the gas! $12,000.00. 330-858-1842.
Jim Bailey is offline   Reply With Quote
Old 09-23-2010, 09:21 AM   #2
426Fred
Liked 2 Times in 2 Posts
Default Re: 1963 Mopar Max Wedge Engine - Complete
I am currently putting together a 1964 Savoy to run in stock. Can I use this motor in a 64 car and what class would I be in, A/SA ? Is there anything I would have to change to make it legal in a 1964 car since it is a 1963 motor? I am very interested and motivated :-)
426Fred is offline   Reply With Quote
Old 09-27-2010, 09:06 PM   #3
Jim Bailey
Sorry Fred: it's a legal 1963 stocker engine. '64 uses different CC heads and pistons. Everything else would be legal. Thanks, Jim... PS, I could throw a set of '64 heads in on the deal. Call me.
Old 09-28-2010, 03:07 PM   #4
treessavoy
Liked 4 Times in 4 Posts
The '63 Max Wedge uses different carbs, rods, intake, pistons and heads than the '64 version.
Rods won't matter as you can use aftermarket rods, '63 uses 3447 carbs while the '64 uses 3705's that flow almost 200cfm than the '63's, intakes are designed differently and have different PN's, '63 is 13 .5 :1 while the '64 is 12.5 :1. Legal aftermarket parts might change some of the above but they will not swap between years and be legal.
JimR
Jim Rountree
Old 09-28-2010, 04:19 PM   #5
Jerry Hatch
Jerry Hatch's Avatar
Fred you have a PM.
In God I trust.
Jerry Hatch is offline   Reply With Quote
Old 09-28-2010, 05:18 PM   #6
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
The six 3447 carb's I had all flowed between 597 and 600 CFM on my flow bench, the 3705 I tested flowed 700 CFM on the dot. The so called 64 mani's are frequently dated May 63 as mine is and they all should have the same part No.
Old 09-28-2010, 09:02 PM   #7
Jim Bailey
Cool Re: 1963 Mopar Max Wedge Engine - Complete
Thanks for the info on the carbs guys! The 1964 manifold is legal on a '63 as are the 518 '64 heads. ( although they can be cut to 81 cc.) The '63 415hp Engine (low comp.) uses a slightly different piston spec than the '64 per NHRA, however, the High Comp. '63 and '64 pistons are the same. The Engine I'm selling is a legal Low Compression 415hp 1963 Engine. Also, I think you could get away with running '63 carbs on a '64, I don't know why you would, but, given the state of "stock" they'd probably let you go since the carbs are too small ! One more piece of info ....a little birdie told me that the '63 ('63 only) 415hp engine will be 405HP in 2011.
Old 09-29-2010, 01:28 AM   #8
treessavoy
Jim,
Can't you substitute Eldebrock carbs for the originals per NHRA?
JimR
Jim Rountree
Old 09-30-2010, 10:41 AM   #9
Bill Brennan
Yes you can.
Bill Brennan 1062 STK
Bill Brennan is offline   Reply With Quote
Old 09-30-2010, 11:52 AM   #10
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
The 63 415 HP has been 405 HP in IHRA for a couple of years now. Must run the smaller carb's on the 63's and the larger carb's on the 64's in IHRA. Who knows what kind of *&^@# NHRA allows these days.
