Old 09-16-2010, 11:22 PM   #1
jjwoller
Default 1971 Camaro For Sale
This is a 1971 Round Tube Chassis Camaro 4-Link Car.
Component List
MagnaFuel Fuel System
Autometer Gauges
MSD 7AL3 Ignition
MSD Crank Trigger
MDS Pro Coil
Stroud Parachute w/Launcher (New)
Stroud Camlock Belts and Window Net
Weld Alumastar Rear Wheels with GoodYear Tires
Weld Alumastar Fronts with GoodYear Front Runners
7.50 NHRA Certification
Strange Aluminum 3rd Member
4.10 Pro Gear
Strange Double Adjustable Rear Shocks
Wilwood Rear Brakes
Wilwood Master Cylinder
Strange 40 Spline Gun Drilled Axles
5/8's Studs
Strange Front Struts and Brakes
Hurst QuarterStick Shifter
Dedenbear AS2 Air Shifter
Dedenbear CC3 Delay Box
Dedenbear TS6 Throttle Stop
Carbon Fiber Drive Shaft
Fire Suppression System for Driver and Engine Compartment
Kirkly Seat
SFI Roll Bar Padding
Removable Mark Williams Steering Wheel
Dual Optima Batteries
Ron Davis Radiator
Aluminum Rear Wing
Removable Glass Doors
Wheelie Bars
Transmission is a Dynamic Transmission PG, Dedenbear Case with converter, trans cooler. The transmission is rated to 1500HP.
565 BBC Big M Block, Brodix Heads, Oliver Rods, Callies Crank, JE Pistons, Jessel Shaft Rocker and Belt, Complete Stef's Dry Sump system with pan. Alchohol Dominator, Moroso Fabricated Valve Covers, Dynatech coated headers. The car has run a best of 5.40 at 130 in the 1/8th and 8.35 at 165 in the 1/4.
Please call 715-574-0951 if interested.
Thanks,
Jeremy
jjwoller is offline   Reply With Quote
