Old 09-16-2010, 07:07 PM   #1
KG-CMF
Default Misc. Parts
1- used- jesel dart buick 1.7 ratio rockers- complete set with hardware, stands, shafts. $400.
1- matched pair 1050 dominators built by David Cook, linkage included. Excellent condition. $ 2200.
1- used- dart buick 55 mm bullet camshaft,3 lobes need repair. Make offer
1- moroso dry sump oil pan for 4 stage pump, 3- 12 an pickups small/ 2 peice crank rear pan seal, windage screen, good condition- $ 300.
1- moroso p/n 22570- 4 stage dry sump pump, with fittings, good new condition. $750.
1- pair dart buick heads with valves 2.15 int x 1.62 ex, valve springs, retainers, 30 cc chambers, 1 head needs repair, $1000.
13- 4.020 bme pistons, .927 pin, 2 brand new, 11 used, nicks on some, $200.
315.542.1195 - kgotie@twcny.rr.com
Kevin Gotie
KG-CMF is offline   Reply With Quote
