Old 09-09-2010, 08:30 AM   #1
Terry Cain
Terry Cain's Avatar
Liked 230 Times in 106 Posts
Default HP adjustments??????
Did any combo's receive hp after Indy?
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 09-09-2010, 03:24 PM   #2
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Thumbs down Re: HP adjustments??????
Yes but not enough !
Old 09-09-2010, 03:38 PM   #3
Casey Miles
Liked 488 Times in 90 Posts
Talking Re: HP adjustments??????
I'm sure that they will pick up the HP that they lost to the NHRA's new factor numbers with cams and or piston changes. They are just screwing with computer tunes now, just wait. I'm sure that those engines haven't been stroked the .013 that you are allowed along with lighter pistons and all the other crap you can do to a "STOCK" engine. Give them some time and I'm sure that the one's that are going mid 9's now in stock, will be going low 9's or into the high 8's.
Casey Miles
248H Stock?
Old 09-09-2010, 03:41 PM   #4
Jim Kaekel
Liked 529 Times in 107 Posts
Default Re: HP adjustments??????
I have not seen where they have made a single change yet. I just checked the 2010 Ford classification sheet and it hasn't been changed. We can only hope that the cars in question get hit with a decent amount of HP, although I'm sure they won't get hit with what they deserve.
Jim Kaekel 3836 STK
Old 09-09-2010, 03:54 PM   #5
X-TECH MAN
Banned
Cool Re: HP adjustments??????
Casey Miles
248H Stock?
Hummmmmm, Maybe someone will build one of these new (blown or un blown) Mustangs or Dodge DP's for IHRA's A/PS (8.0 lb break) class that has a 12.05 index.......LOL. I can see low high 9's to low 10's thru the Flo master mufflers ! Lets see.....How about the 10.0 lb class (C/PS) in pure stock. Mid 10's on a 12.75 index maybe! Damn it gets better and better. I guess these new cars are the way to go if you can afford one.
Old 09-09-2010, 04:28 PM   #6
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Jim,
The 2010 352 Ford got 10 ... none of the other Ford combos went 1.25 under, so they won't get HP till the end of the year ...
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 09-09-2010, 04:42 PM   #7
NewHemi
NewHemi's Avatar
It seems that I remember Chris "Drooze" making the prediction here quite a while ago, that these cars could get into the eights, and he got ripped up, down and sideways for saying it....
Wonder who is smiling now?
And as some of you all suspect, and some even forecast, you "aint" seen nothing yet...
David
The New Hemi Guy
NewHemi is offline   Reply With Quote
Old 09-09-2010, 04:48 PM   #8
Jim Kaekel
Chuck:
Where do you see that listed? I just checked the 2010 Ford classification sheet and it still shows the 352 at 285.
Jim Kaekel 3836 STK
Old 09-09-2010, 06:33 PM   #9
Chuck Beach
Jim,
You need to 'clean up' your PC. Do the following periodically to keep your PC clean ..
Go to start
Select all programs
Select accessories
Select system tools
Select disk cleanup
Under disk cleanup I would check the following if it applies:
1) downloaded programs
2) Temporary internet files
3) Office webpages
4) Recycle bin
5) Temporary files
6) Web/Client publisher temporary files
7) Temporary offline files
Click Ok, then when it is done, go back out to the NHRA website and re-open the spreadsheet.
Chuck Beach
3340 STK
Old 09-09-2010, 07:09 PM   #10
JSLRacing
or hit CTRL and REFRESH at the same time and it will reload the page instead of using the cached...
Jason Goldsack -
1997 Track Champion - St. Thomas Dragway
1997 Race of Champions Winner - Indianapolis, IN Div. 3 finals
JSLRacing is offline   Reply With Quote
