Old 09-05-2010, 11:52 PM   #1
RJ
Default Comp/Super Stock parts
1 new set JE 4.182"+/-.005" bore, .0300" +/- .000050" axial x .122" radial steel diamond lapped CrN top rings, Great for Comp, or Super Stock - $275
2 new sets JE 4.182"+/-.005" bore, .0325" +/- .000050" axial x .124" radial steel diamond lapped napier 2nd rings, $125 per set
2 new sets JE 4.185"+/-.005" bore, 2mm axial x .120" radial oil rings, 3-5 lbs. drag, $125 per set
1 new set JE .866" x 2.000" x .150" wall DLC coated , very high end GKH material wrist pins, new never used, great for small or big block super stock, or small block comp motor - $300
1 new set Calico coated CB1663H STD Honda journal rod bearings, new - $125
1 new set Clevite CB1663H STD Honda journal rod bearings, new - $100
1 new set ACL 5M909H STD 3/4 groove main bearings, new - $50
1 new set 426 Hemi spark plug tube and seal kit P4120294 - $60
All parts + shipping from Charlotte, NC area, Paypal accepted.
Don't be afraid to make offers, this stuff has to go!
RJ is offline   Reply With Quote
