Thread Tools | Search this Thread | Display Modes |
Liked 26 Times in 10 Posts
2007 ATC Aluminum Car Hauler:
22' 5" overall length 100" wide, solid alum. deck, 4 wheel electric brakes on tandem 3,500# Torflex EZ-Lube axles.Curb weight 1,050 lbs, GVW 5,500 lbs. 36" beaver tail, radial tires,styled steel wheels w/center cap's,removable fender's,Fold down number plate and bracket,tongue jack,2 5/16 coupler,sealed clearence lights, 4 SS recessed D ring tie downs, 60" ramps,with hide away side compartment, rear stabilizer jacks. This is a top of the line all aluminum trailer that tows like a dream and with less than 500 total miles since new. Over 1,000 lbs less weight empty than a comparable steel trailer means 1,000 lbs less weight you will be towing while still having a 4,450 lb payload capacity.CALL 508-269-9611 OR E-MAIL ba1927@aol.com for any additional info or picture's ASKING $4995 OBO 2005 IMPERIAL: 19' Car Haulers have two 3,500 lbs Dexter Torflex EZ-Lube Axles with ST205-75R15 tires, 8'6" Overall Width - 6'10" between Fenders. The 19' model has a 14' Deck with 5' Dovetail Full Tread plate Floor LED Peterson Sealed Beam Stop, Turn & Tail Lights Only All Wiring in Conduit (connections soldered & silicone sealed) Colors Available: Black, Red, Silver Metallic 20" x 72" Self Storing Ramps with Ramp Locks Primer (2 coats) - Paint (2 coats) on ramps Emergency Break-A-Way Kit w/Charger Electric Brakes on all axles 2-5/16" Coupler (45' model has 2-5/16" Fulton 25,000# Coupler) 5/16" Safety Chains (45' model has 3/8" Safety Chains with latch hooks) Aluminum Rock Guard on front of trailer, fenders & taillights Swing-Up Jack Recessed Floor Tie Downs 19' model - 4 Spare tire mount-spare tire & chrome rim $6600 call 508-269-9611 or e-mail ba1927@aol.com THANK's |
