Old 08-21-2010, 12:55 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default open race car hauling trailer builders?
Racers,
I am in the market for an open car hauler trailer. The lower the better with long ramps. Maybe a removable left fender so the door will open. Also enough tongue length for a small tool/storage box. A 16 foot bed length is what I have in mind with maybe a 4 foot tongue length.
Let me hear about companies who build such a trailer.
Thanks
Old 08-21-2010, 01:02 PM   #2
BlueOval Ralph
Banned
Default Re: open race car hauling trailer builders?
T&E will build open also Featherlite has some have had 2 of theirs well built
BlueOval Ralph is offline   Reply With Quote
Old 08-21-2010, 02:47 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: open race car hauling trailer builders?
If you are planning on a custom open trailer, you may want to consider the following:
* At least 3,500lb axles. 5,000lb wouldn't be a bad idea.
* Open middle deck so you can work on the car from under the trailer. But that may compromise how low you can go.
* I had one built to accept a 2'x2'x6' construction site tool box. May need some trimming to the "feet". But most fuel jugs fit, they have a very durable epoxy coating, weather proof and are very secure. Lots of storage. Maybe a 4' would be enough, but a 6' helps protect the car from rocks kicked up by the tow truck.
* Slight down angle at the rear to help loading and reduce ramp length.
* Get a heavier duty version than you think you need. Better in the long run.
Old 08-21-2010, 04:54 PM   #4
Philip Saran
Liked 14 Times in 11 Posts
I have a 18 ft open (full steel deck) with 4 ft dove tail mfg
by Quality Trailer Inc in Ohio. It has 3500 lb twin axels and
7000 gross. and electric brakes on all 4 wheels.
Besides using it for hauling cars I also use mine to haul
freight so the full deck comes in handy.
In 2007 it cost the original owner about $4K to purchase,
I bought it in the beginning of 2008 at a great savings.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 08-21-2010, 05:26 PM   #5
BlueOval Ralph
Banned
If buying a trailer get the 5000lb axles it get's you 12x2 brakes and larger wheel bearings on the 3500 lb you only get 10x2 brales and the outer wheel bearings are the same as a Ford Maverick or Pinto.
Old 08-23-2010, 07:40 AM   #6
Chris Hardy
Guest
Posts: n/a
Appalachian trailers makes a nice, very inexpensive trailer. The paint is poorly done. But you could probably request a higher quality job. 330-222-2468.
Chris
231-740-5862
Old 08-30-2010, 09:38 AM   #7
ss wannabee
Liked 7 Times in 7 Posts
A bit further away from you but Eliminator Trailers by the Unger & Wilhelm Co. in Syracuse, NY has been building decent open race car trailers for years. They were very popular with Northeast-area races and with many racer-friendly options. I'd give them a try!
ss wannabee is offline   Reply With Quote
Old 08-30-2010, 07:06 PM   #8
Tom Simon
Take a look at the Texas Rollback trailers. Not the cheapest open trailer, but I saw one demonstrated at a Good Guys show about 8 years ago... No ramps to mess with, no hydraulic ram, the tow vehicle does all the work. I've not seen an open trailer design that I like better.
http://www.rollbacktrailers.com/how_it_works.htm
Tom Simon is offline   Reply With Quote
Old 08-30-2010, 07:34 PM   #9
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
I like my Classic Trailer, diamond plate full deck, two 5200 lb axles, both fenders are removable, last three feet is a beaver tail, and has hidden ramps. Classic Trailer is in Sturgis , Michigan .
Old 08-30-2010, 09:26 PM   #10
Greg Barsamian
Liked 427 Times in 97 Posts
U&W trailers has been closed for a few years now.
I still have an 04 18ft. Eliminator that's never had a car on it! 300 miles from Syracuse to pick it up!
It's NOT "On sale" It's "For Sale"
