Old 06-21-2010, 08:11 PM   #1
Greg Greening
Liked 4 Times in 2 Posts
Default 87 Camaro I/S or I/SA
305 TPI 241 auto 245 stick Have everything to make this car auto or stick. It has Holley Commander 950 computer, MSD digital ignition, Aeromotive fuel system, VDO gauges, Lakewood struts, QA1 single adjustable rear shocks, Moroso trick springs, Pete-Z traction bars,Ktre 12 bolt with Moser 33 spline axles, Moser spool, 5.38 lightened progear,Wilwood brakes all around, Weld alumastars front, Bogart alumalites rear, MT tires, Engine has Cp pistons, Bullet cam, PAC springs & retainers, Ferrea valves, Stewart oil pump, Csr water pump, East coast starter & alternator. Auto trans is 2.75 low gear, Auto 1-2 shift, deep alum pan, PTC 8" convertor, Reactor aluminum flexplate,Turbo action shifter. Stick trans is 3.29 low gear Jerico, Long shifter, Advanced 10" single disc clutch, Lakewood bellhousing. Asking $21500 with auto $24000 with stick or $26500 for everything. Call for info 573 864-9706 Email Greenstk594@aol.com
Greg Greening is offline   Reply With Quote
