Old 05-30-2010, 09:35 PM   #1
BA1927
BA1927's Avatar
Liked 26 Times in 10 Posts
Default 2007 atc 18' all aluminum open trailer
2007 ATC Aluminum Car Hauler:
22' 5" overall length 100" wide, solid alum. deck, 4 wheel electric brakes on tandem 3,500# Torflex EZ-Lube axles.Curb weight 1,050 lbs, GVW 5,500 lbs. 36" beaver tail, radial tires,styled steel wheels w/center cap's,removable fender's,Fold down number plate and bracket,tongue jack,2 5/16 coupler,sealed clearence lights, 4 SS recessed D ring tie downs, 60" ramps,with hide away side compartment, rear stabilizer jacks. This is a top of the line all aluminum trailer that tows like a dream and with less than 500 total miles since new. Over 1,000 lbs less weight empty than a comparable steel trailer means 1,000 lbs less weight you will be towing while still having a 4,450 lb payload capacity.CALL 508-269-9611 OR E-MAIL ba1927@aol.com for any additional info or picture's
BA1927 is offline   Reply With Quote
