Old 05-18-2010, 11:36 AM   #1
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default Fuel Keep, Ice for heads and any other tips ?
Ok Ive got a few questions I simply have no idea on. For the veterans and ones on here I look to for good info......
What is the purpose of icing the heads in teardown ? Is it for runner size / ccing ? I cannot imagine it actually makes a differenece so, is that what its for if not what is the purpose ?
In as much as a checking lifter is concerned is that something I have to supply ?
Also were running C-11 What can I expect fuel keep time to be on a Jug bought trackside ? Ive heard horror stories about failing fuel check and I was a wee bit worried about that at Norwalk, the Fuel we had was in the tank (yes really) and Jug from Indy.
Also in as much as Front Runner Pressure, I had been running 35, The night I ran the 10.59 I was at 29.5 however I wanted to air them but didnt have time. What is best for this and what is it based on ? I want to get the car airborne with the 2 step but am I looking for higher lower or is it simply a preference.
Our teardown is looking good so far everything right in line #1 and #3 were a little leaner than the rest but safe on EGT's by far. Ill trim those injectors seperate.
Cheers
Chris
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
