Old 05-16-2010, 05:17 PM   #1
Rory McNeil
Default 5.0L SB Ford valve springs
I have seen to have lost the part number for the valve springs on my 5.0L 85 Mustang Stocker. I was wondering what springs other guys are running on these engines. I do know that my old springs are Comp Cams products, as are my retainers & keepers. As far as I know, the 86-95 5.0L Fords should all use the same spring , which is a single. Any suggestions?
NHRA 6390 STK
M/S 85 Mustang
Old 05-16-2010, 07:10 PM   #2
Gary Smith
Gary Smith's Avatar
Liked 132 Times in 30 Posts
Default Re: 5.0L SB Ford valve springs
#999 outer are the heavy ones, but I've got #911 that Earle Holt suggested I try.
Gary Smith
"another broke racer spectating"
Gary Smith is offline   Reply With Quote
Old 05-16-2010, 10:48 PM   #3
Notch1320
I run the Comp #999's as well. Just be sure to notch the rockers!!!
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 05-17-2010, 09:10 PM   #4
Earle Holt
Liked 4 Times in 1 Post
Yes Rory, the 911's don't need clearancing and I've run them without any issues up to 6500. The 999's are a bigger, stiffer spring, but require rocker work for clearance.
Earle Holt 1055 Stock
Earle Holt is offline   Reply With Quote
