Old 04-16-2010, 09:48 AM   #1
Floyd Gomez
Floyd Gomez's Avatar
Default Parts Needed
We are in need of parts to build a 350 for the 79 Z-28 stocker. We need roch carb # 203 manifold # 376 and or 346249 head # 462624 and or 376450. Also need spare blocks if anyone has them. Looking for a used set of caltracs, center console and used tach w/ shift light. Any ignition parts and will consider a built 350 stocker motor if the price is right.
Floyd Gomez is offline   Reply With Quote
Old 04-16-2010, 08:33 PM   #2
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Default Re: Parts Needed
Floyd,Just to let you know you do not have to have the correct year carb.,as long as it is a 750cfm Quadrajet you are ok,I would go with a 207 or Newer Edlebrock myself,Some are going to the newer 750 front inlet carbs.you really don't have to have the console to be legal either lots of stockers have removed the console's,Just thought I would suggest some things that might help you in your build.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 04-16-2010, 09:07 PM   #3
Floyd Gomez
Thanks Monte. Do yuo know the Eldebrock number?
Old 04-17-2010, 07:35 AM   #4
Logus
Floyd check this link. Very large 2nd gen Camaro website. Should be able to find your general stuff, body, interior, cores , etc. here, "NOT" the stock elim. specfic stuff, foreign concept to most there.
CalTracs go fast, when they show up.
http://www.nastyz28.com/forum/index.php
Logus is offline   Reply With Quote
Old 04-17-2010, 06:06 PM   #5
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Floyd,
You'll want to use the 624 head and the 249 intake. I run this combo. If you have any questions shoot me an e-mail or a PM.
Joe
Joe Marcinowski 3377 STK
Joe Marcinowski is offline   Reply With Quote
Old 04-17-2010, 07:56 PM   #6
Floyd Gomez
Originally Posted by Joe Marcinowski View Post
Floyd,
Joe
Joe Check your PM's
Old 04-17-2010, 08:43 PM   #7
Mike Fuller
Liked 203 Times in 80 Posts
Floyd
I have a Autometer Pro Comp 9000 RPM Tach with two stage shift light and memory. PM me if you are interested.
Mike Fuller 396 STK
3961 SS
Old 04-21-2010, 08:48 PM   #8
Joe Marcinowski
Floyd,
Check your PM's.
Joe
