Old 04-15-2010, 10:06 PM   #1
LilBlueDeuce
Default Jegs wheels and 5/8" studs
Jegs says none of their Jegs brand wheels will work with 5/8" studs. I borrowed a Jegs Sportlite wheel from a friend and it looks it could be drilled a minimal amount to make the 5/8" studs fit. The wheel surface around the stud holes also seems like it is flat enough that it would work with the spacers for the 5/8" studs. But before I bought a set, I was wondering if anybody has successfully used any of the Jegs brand wheels with 5/8" studs?
LilBlueDeuce is offline   Reply With Quote
