Old 04-10-2010, 06:39 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969 L78 396 Shortblock and #840 Heads
1969 L78 396 4 bolt standard bore block cleaned and magged casting number 3955272 dated H-27-8. Front pad stamped CE961018 and is a warranty counter exchange block. I also have the factory 11 to 1 pistons with the 3/8 dimple rods and the 6223 crank freshly turned 10 under on the mains and 20 under on the rods $2500. I also have a freshly rebuilt stock set of 3919840 square port heads both dated A-22-9 with no porting $1750. Can ship if you cannot pick them up and can be reached at 330-770-2517 for any questions.
dlv4540 is offline   Reply With Quote
