Old 04-03-2010, 06:10 AM   #1
mannymen
Liked 13 Times in 7 Posts
Default Failing Fuel Check?
When any of you fail your fuel check after a run are you then draining the fuel and refilling it with new fuel and then flushing the entire system for a few seconds?
Or are you pulling your tank and scrubbing it clean and will the fuel check staff verify your new fuel before using it?
Someone mentioned scrubbing their tank in a post awhile back, but what does that exactly mean?
N/A
mannymen is offline   Reply With Quote
