Old 04-02-2010, 07:02 AM   #1
Dan Bernay
Liked 13 Times in 8 Posts
Default Pinion Angle
With car on level surface where is best place to put protractor to check/adjust pinion angle?
Thanks,Dan.
Old 04-02-2010, 12:19 PM   #2
Floyd Gomez
Floyd Gomez's Avatar
Default Re: Pinion Angle
I always drop the shaft but that is my preference
Floyd Gomez is offline   Reply With Quote
Old 04-02-2010, 03:33 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Originally Posted by montys 55 View Post
dan if its a rear cover style remove the cover and use the cover surfice.
if its a ham type use the mounting surface if the housing is empty or you can remove the driveshaft an use the flat on the front of the pinion
Only trust the yoke if it's a machined billet piece from Strange or Mark Williams . .....The forged or cast type are sometimes ground ,not machined at the U- bolt surface. ...........this method works well otherwise. ..Tom
Old 04-03-2010, 05:19 AM   #4
Dan Bernay
Thanks for the help guys!
