Old 03-31-2010, 09:43 PM   #1
Bart Nelson
Default BBC 472 $5500 intake to pan
Currently in my Pontiac Astre. runs 8.9s wide open @ 2700lbs on alcohol
Less than 100 passes since freshened
Brodix heads, eldebrock intake, manley rods, SRP pistons
Crane Roller cam, roller rockers with stud girdle.
Originally this was a Reher-Morrison Super Series 468
Rated @ 750 hp. Houston Engine installed larger camshaft and bumped the compression up from 13 to 1 - to 14.5 to 1. Then I put it on alcohol.
Can see run in car!
Bart281-924-2759
2008 Summit Super Pro ET National Champion
Bart's Dominator Service
Bart Nelson is offline   Reply With Quote
