Old 03-26-2010, 07:29 AM   #1
Greg Hill
Liked 279 Times in 68 Posts
Default Another bogus hp rating.
Just so you guys in some of the lower classes think you're immune form the new crate motors take a look at the 2010 4.6l motor from Ford rated at 235hp. Also look at the 2007 Ford GT 4.6l motor rated at 300hp. These motors are basically the same except for two things, first the crate motor is 11 to 1 compression and the GT motor is 10 to 1, and the throttle body on the crate motor is 2 @ 62mm and the GT motor is 2 @ 57 mm. This is basically legalized cheating. A motor that probably should be 310 or 315 rated at 235. How much more bogus can it get?
Greg Hill 4171 STK
