Old 03-14-2010, 01:00 PM   #1
Ross Family Racing
Liked 51 Times in 14 Posts
Default Locking Trans Dip Stick
Does anyone make a flex assembly that will pass the rule for locking transmission dip sticks. We currently run a unit purchased from Mancini Racing and the stick is sealed with o-rings and fits tight,hafta really tug on it, to get it out. The standard tube style will not work in our Avenger because the mid mount is in the way. Any suggestions?
Jeff Ross
Ross Family Racing is offline   Reply With Quote
Old 03-14-2010, 01:20 PM   #2
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
Default Re: Locking Trans Dip Stick
I went to my local U-Pull It junkyard and got a couple locking dipsticks from newer GM vehicles. You can then cut and weld your dipstick to the locking one, remark the locking dipstick to your length or put your dipstick in your trailer and use just the locking portion of the locking dipstick in your dipstick tube if it is the same diameter.
Patric Fox is offline   Reply With Quote
Old 03-14-2010, 02:07 PM   #3
Jim Storms
Liked 4 Times in 2 Posts
Cool Re: Locking Trans Dip Stick
In my Avenger i had the same issue! no room! i just installed a short dragster style it's fine. once you install the propper fluid amount no need to check it after that, so why have it in the way....
Jim Storms is offline   Reply With Quote
Old 03-14-2010, 03:50 PM   #4
treessavoy
Liked 4 Times in 4 Posts
I think Lokar has a flexible locking dip stick for both engine and trans.
JimR
Jim Rountree
Old 03-15-2010, 12:23 PM   #5
John Musial
Liked 51 Times in 3 Posts
Thumbs up Re: Locking Trans Dip Stick
Jeff, The Lokar piece is the way to go.
John Musial is offline   Reply With Quote
Old 03-15-2010, 12:26 PM   #6
tim worner
Liked 126 Times in 20 Posts
Lokar has the set up for you.
the quick connect deal is the best. I can get you a good price on one if interested. Tim
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 03-16-2010, 08:05 AM   #7
Ross Family Racing
Does Lokar have an application fot the 904 Torqueflites? I was on their website and did not see one.
Jeff Ross
Old 03-16-2010, 07:43 PM   #8
Kent Hanley
Lokar has a flexible dip stick tube but its a pain to install. You have to remove the pan, so you can bolt it to the case. Of course it doesnt push in easy , you really have to work with it. I was replacing my non locking Lokar dip stick tube with the locking one and the bracket doesnt match up. So you have to drill new holes for the bracket. All this and its not easy to read, i dont know why other than the tube hangs so low in to the pan. But its flexible, its got that going for it. oh yea its also over $110
Kent Hanley is offline   Reply With Quote
Old 03-17-2010, 08:56 AM   #9
Ross Family Racing
Thanks for all the different suggestions. I'm sure we can figure something out.
Jeff Ross
Old 03-17-2010, 05:25 PM   #10
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
Talking Re: Locking Trans Dip Stick
Jeff copy and paste!
http://www.lokar.com/interior_pages/transdipstick.htm
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
