Old 03-03-2010, 05:52 PM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969 #840 Square Port Heads and L78 Block
I have a couple sets of 1969 3919840 square port heads. First set is dated A-28-9 all cleaned and magged and stock $1250. Second set is dated C-25-9 $1250 along with one stock single dated E-1-9 $650. 1969 3955272 4 bolt 396 block with the JH code stamped on the front pad dated L-10-8 and standard bore with the original pistons and a steel 6223 crankshaft $2000. 330-770-2517 for any questions and can ship these parts if you cannot pick them up.
dlv4540 is offline   Reply With Quote
