Old 02-17-2010, 09:52 PM   #1
taylor51
Default xts camshaft belt drive for sbc and mellings pump/pick up
I have the following items for sale:
XTS camshaft belt drive for sbc. part #xcexts70003, in perfect condition, has 4 dyno pulls only. sold motor and buyer wanted a timing chain instead for a lower cost buy, my loss your gain here. following are the specs: "Engineered for precise, improved valve timing at an economical cost. Direct, bolt-on Pro-Series XTS Cam Drive System may be installed without machining. Designed in conjunction with Goodyear using the latest carbon fiber technology for improved belt life and tooth engagement, system features wear resistant, 8000 series black oxide coated steel cam and crankshaft hubs, and a billet aluminum back cover with an O-ring seal, effectively eliminating paper gaskets. Hubs, timing belt, back cover and hardware are included." paid $903.00 new, asking $550.00 shipped to your door.
mellings m55hv oil pump with moroso hd pick up tube, for a sbc, pump has pick up both bolted and professionally tack welding to body, pump was disassembled, inspected, cleaned and reassembled. brand new and ready to be bolted in. pick up is for a 8 1/4 deep pan. asking $45.00 shipped to your door.
can email pick of items.
thanks,
mike taylor
641-425-0391 cell
641-424-6111 work
mgt16@mchsi.com
taylor51 is offline   Reply With Quote
