Old 02-15-2010, 02:13 AM   #1
Steves68Nova
Steves68Nova's Avatar
Default Factory LS-6 still in the crate
http://cgi.ebay.com/ebaymotors/Chevr...item19b9d8c488
Wish I had seen it earlier.
Steve
Steve Prado
Rudy, AR
S/ST4202 H/R 4203
Steves68Nova is offline   Reply With Quote
Old 02-15-2010, 06:39 AM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Factory LS-6 still in the crate
They sold for under $2500 from my local Chevy dealer back in the late 80's......
Rich Biebel
S/C 1479
Stock 147R
Old 02-15-2010, 12:59 PM   #3
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
I remember in the 80's listening to Chevy guys talk about that engine available from GM.
The thing that stuck in my head was this prominent GM racer telling a potential LS 6 buyer to make sure he completely disassembles that engine and check the clearances.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 02-15-2010, 05:41 PM   #4
denny harvey
i got one from bowman chevy,took it home ,put a roller cam and 850 holley.dam thing ran 11.os with a hemi 4-speed in a 3200# 8 inch tire nova.like to have a couple more of those...denny
denny harvey is offline   Reply With Quote
Old 02-15-2010, 06:38 PM   #5
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Excellent advice, we bought an LS7 (454) crate engine from the "general" and it was not really ready to race with. Assembly dirt in pan,some bolts not torqued 100% etc...
Tim H is online now   Reply With Quote
Old 02-15-2010, 07:13 PM   #6
Rich Biebel
I installed one in a friends '69 Camaro. It was an all steel bracket car except the hood. Powerglide with a 4.88 gear. The very minimum we did to those LS-7's was pull the heads and cut the guides down to prevent the retainers from httting them. We usually also milled them .020" and cleaned up the valves and seats. That '69 Camaro went 10.80 at 124 with a good 8' converter on it's first decent pass.
That engine went as quick as 10.40's at 128 but did hurt the bottom end eventually. I think it had maybe 150 runs when it failed....
We also highly recommended a full disassembly and race prep with a lot of upgrades and parts changes.....
Bush the rods
Hone the block with a plate
Check the crank for being straight
Deck the block
Check the line bore
Balance it
Replace the rings and bearings
Do the heads...VJ and some mild port work
Change the cam to a bigger solid or a roller
They were a very good base for a race engine but not a good idea to race one right out of the crate......
Street duty would have been fine unless you really beat on it......
Rich Biebel
S/C 1479
Stock 147R
