Old 02-06-2010, 01:14 PM   #1
mweb
Default 327 SS Bowtie Shortblock & Parts
GM Bowtie block, 4.060" finished bore, C-K 10 plate honed, ARP head studs installed, .843" bronze lifter bushings (LSM) installed (honed to size for Crower Cut-Away Severe Duty lifters), LSM 55mm cam tunnel w/slider bearings installed & fitted to LSM camshaft, steel billet 4-bolt main caps installed on 3 center mains, block align-honed (sunnen machine). China wall milled .135", decked for 327 SS application (.015" Fel-Pro gasket required), block face clearanced for Jesel cover, deck pins installed.
Moroso rear seal adapter included.
327 cast crank .010"/.030" stroked .015" & all strokes indexed.
Clevite rod & main bearings (crank ground to correct clearances).
Manley 5.7" superstock rods w/cap screw bolts.
Wiseco pistons (10 pistons) slipper skirt design, coated skirts. No top ring groove, no valve pockets. Pistons are pin-fitted to Patterson tool steel wrist pins.
Speed-Pro R-20100 +.065" .043"/.043"/3/16ths"
Patterson tool steel wrist pins .927" X 2.500" X .120" wall.
LSM 55mm camshaft 280/.440" int., 284/.450 exhaust 107 l/c
4/7 swap firing order.
Crower Cut-Away Severe Duty roller lifters, fitted to lifter bores.
All parts above are new in the box. $5000 for everything.
Also have:
Jesel Belt Drive (SBC) w/new upper seal plate & new belt (still in plastic packages), new Garlock lower seal. $600 w/above shortblock or after shortblock sells.
Jesel Pro Series Shaft Rocker Set KRA-04401 for above 327.
1.8 Int./1.7 Ex. New in the box w/all parts. Will sell w or w/o motor.
$1050
SBC head castings:
1 pr. 3917293
1 pr. 3817291
1 pr. 3890462
All castings are good take-offs. $60/pair
1 SBC Intake manifold 3919803 $50.00
Buyer pays shipping.
mweb is offline   Reply With Quote
Old 02-06-2010, 02:14 PM   #2
Michael Kilduff
Default Re: 327 SS Bowtie Shortblock & Parts
PM sent
Michael Kilduff is offline   Reply With Quote
Old 02-06-2010, 06:49 PM   #3
tj310
Whereabouts are you? Thanx Trevor
