Old 02-04-2010, 01:10 PM   #1
Trevor Weiss
Default 1968 Camaro
Base model camaro no engine or trans. Perfect canidate for a tube chassis car super street, super gas, super comp or what ever. This car needs outer roof panel, both 1/4 panels, wheel house's, tail lamp panel, trunk and floor pans, lt fender, deck lid, front & rear glass.
It has both doors that are repairable, rt fender, rad support, header & cowl panel, steering column w/steering wheel, both original front seats (need recovering), 10 bolt rear end, front sub frame but has front cross support cut out. So if front the sub frame is to be used it would need to be replaced to look original or it can be repaired if you choose not to go with a tube chassis.
This car could be made into a stock or super stock as well using the lighter aftermarket sheet metal.
Asking $950.00
I also have NEW left and right full 1/4 panels (with sails) that i would want $400.00 for the pair ($200.00 ea). They list for $369.95 ea ($739.90 pair) in a camaro catalog.
I was going to build this for my son's first street car but he does'nt want it he wants a 68-72 corvette instead. Go figure
I do not have a title because the state of Georgia does not issue titles for cars this old. So all I can give is a bill of sale. I've had this car for about 6 years. Thanks Trevor Weiss
Trevor Weiss 2891 STK
Trevor Weiss is offline   Reply With Quote
Old 02-04-2010, 11:42 PM   #2
scott helms
scott helms's Avatar
Default Re: 1968 Camaro
hey trevor you have p.m.
SCOTT HELMS Stk,SS 2540
scott helms is offline   Reply With Quote
