Old 01-31-2010, 10:52 AM   #1
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
Default Stock Tech Question
My brother is looking to buy a local ET Bracket car and convert it to a Stock Eliminator car. Have most of the pieces to put it together. It has a factory floor but has the leaf springs moved into the frame, but the factory frame rails are still there with the factory spring mounting holes. So moving the springs back to the factory location is not a problem. But the car has aluminum wheel tubs. Is it possible to install steel wheel tubs in place of the aluminum and be legal for Stock,provided the steel is at least the same thickness as the factory?
Patric Fox is offline   Reply With Quote
