Old 01-17-2010, 09:14 PM   #1
budgetracer
Default Axle tube replacement?
I bought a nasty looking 12 bolt. The tubes have brackets welded nasty. wrong location and all. I got a good deal so I want to put new tubes and replace everything. I have rebuilt many rears but never replaced axle tubes. How do I do this? Thanks in advance!
budgetracer is offline   Reply With Quote
Old 01-17-2010, 09:42 PM   #2
bob3240
Liked 16 Times in 5 Posts
Default Re: Axle tube replacement?
I did that recently. Saw the tubes off at the housing, carefully cut the inside of the tubes with a torch. cut 2 slots opposite each other without cutting into the housing. Also torch out the spotwelds in the housing. Then chisel out the segments in the housing. It's a pretty rough job! Then buy some tubing the correct dia. and wall thickness and cut them to length. The holes aren't a std. size so you will need to machine the ends of the tubes on a lathe to about .003" press. Heat the housing and then pound the tubes in and weld them in with nickel rod. Then you are ready to weld your brackets and ends on. Be certain of the length measurements. Bob Michael.
bob3240 is offline   Reply With Quote
Old 01-17-2010, 09:51 PM   #3
5413ss
I did the same thing, bought a camaro 12 bolt and the tubes were bent, torched though where the brackets were suppose to be. Anyway the spot welds on the case are some kind of Nickle or something, drill bit will not touch them. I ended up haveing a buddy with a mill and he milled them out or something, didn't cost me anything so that was cool. I think Currie will replace them check out their website.
Patrick
http://www.currieenterprises.com/CES...e.aspx?id=1190
Patrick McGrath
5413ss is offline   Reply With Quote
Old 01-17-2010, 11:43 PM   #4
budgetracer
I could cut and grind the brackets off. But it looks like chunks of bird doo around the brackets. I am going to cut them off and grind 1st after what all you folks suggested. I have nothing to loose. If its junk underneath-burned through what ever then I'll do the replacement tubes.
Old 01-18-2010, 09:29 AM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Blow out the welds with an Airarc torch or a plasma cutter, an accetyline torch will not cut the welds ..........I put a plate on the inside and push the stub out with a short hydraulic ram. ......Don't overheat the casting when you press in the tubes, 650 to700 deg is plenty. .....Tom
Old 01-18-2010, 10:06 AM   #6
rx dealer
Liked 53 Times in 13 Posts
Replace both sides with chromoly tubing and brackets and have it TIG welded even if it's a street car... Luke
rx dealer is offline   Reply With Quote
