Old 01-17-2010, 11:08 AM   #1
6T9chevelle
Default 69 chevelle ss parts for sale trans, suspension, etc
I have the following parts off of my 69 chevelle SS for sale:
Complete 4 speed setup including muncie m20 trans, shifter and rods, bellhousing, pedal assembly, driveshaft. Should be all parts for conversion to another car. $1500.00
Rear factory springs, 25.00
Front big block springs, 50.00
rear 12 bolt control arm set, 125
front control arms upper and lower 200.00 Looks like the ball joints have been replaced recently.
cast iron intake manifold high rise for q jet. 100.00 casting number 3931067
pair of exhaust manifolds from bbc bead blasted 100.00 cast # 3914613 & 3916178
complete rear drum brake setup 100.00
front sway bar 1" 25.00
I am located in Lincoln, ne
Jeff 402 430 1296
6T9chevelle is offline   Reply With Quote
