Old 01-14-2010, 10:34 PM   #1
Kris
Liked 2 Times in 2 Posts
Default 440 w/ Indy top end
Indy top end (heads, intake, roller rockers and valve covers) these are the dash 1 heads, magnum block w/ aluminum main caps 55 over, steel crank, eagle rods, wiseco flat tops, Comp roller cam, Milodon gear drive, external oiling system, new rings and gasket set, needs bearings to be put together, several pans, flexplates and flywheelstke it all $3500
Kris is offline   Reply With Quote
Old 01-16-2010, 05:35 AM   #2
GTX JOHN
Smile Re: 440 w/ Indy top end
Where are you located?
Old 01-17-2010, 05:23 PM   #3
wirtzcf
Default Re: 440 w/ Indy top end
I'm interested too - where are you located and can you send pics? wirtzcf@hotmail.com
Thanks
wirtzcf is offline   Reply With Quote
Old 01-19-2010, 11:23 PM   #4
Kris
I am way up here in Maine!
Old 01-29-2010, 10:54 PM   #5
Kris
Motor has been sold.
