Old 12-29-2009, 12:39 AM   #1
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
Default Aluminum Racing Seats..........
how much do they weigh? How much do the poly seats weigh?
Stephen & Horace Johnson is offline   Reply With Quote
Old 12-29-2009, 09:57 AM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Aluminum Racing Seats..........
the jaz aluminum seat is 11 lbs. with a cover. i can't give you an exact weight difference between the 2. but i will tell you that i will not mount a poly seat in any car i build. the inserts pull out of the bottoms and it's always a pain to mount the back of the seat. you also have to make an access hole, so you don,t crush the seat when you mount the back to the cage. just go with aluminum, leave the poly seats for those 60's style dune buggies.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-29-2009, 10:00 AM   #3
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Summit online or Jegs should have a weight, theyre all different depending on model.
Chris "drooze" Wertman is offline   Reply With Quote
Old 12-29-2009, 02:19 PM   #4
Jeff Lee
Jeff Lee's Avatar
I'll bet poly burns a lot quicker and has a nice aroma when burning...
Jeff Lee 7494 D/S '70 AMX
Old 12-29-2009, 02:25 PM   #5
treessavoy
Liked 4 Times in 4 Posts
Horace,
Back when we all raced around AL at places like Green Valley, Sylacaga..(sp), Huntsville, the Mountain at BIR and the rest I ran a Jaz seat in my '64 Max Wedge and it was such a hassle that I went back to the original bench seat.
JimRountree
Jim Rountree
Old 12-29-2009, 04:46 PM   #6
Thanks I have poly seats in the car, I was trying to justify whether it's worth goin to alum seats. My seats weigh 17lbs with bracket and seat cover. Thanks
Stephen Johnson #2162
Horace Johnson #2167
SS/D NHRA-IHRA
Old 12-29-2009, 07:07 PM   #7
not on the sites, i looked at that last nite
