Liked 22 Times in 22 Posts
is there any horse power difference between a stock type pump, a external pump, or in pan billet pump, as far as turning it goes?
don,t have one |
Liked 333 Times in 180 Posts
yes--Comp 387
Liked 9 Times in 3 Posts
i can't give you any exact numbers but on an external belt driven , just lowering the oil pressure makes a noticable difference when priming it with a drill.
Mark Markow 171 ss/tb |
thanks guys, but which one is better? in comps opinion, i have all 3, which one would you run?
don,t have one |
what engine- what rpm -what type/class of racing?? comp 387
ss/cs g/sm 10400 rpm thanks comp, no. we will not be a threat, just want to get in.
don,t have one |
Randy-- sent u a PM--- Comp 387
thanks guy, you have been a big help. sent you a pm hope it went through.
don,t have one |
got it sent u another PM--comp 387
Hi Randy,
I also run a SS/CS Small Block Chevy and I use a external belt driven Razor Combination oil pump/vacuum pump unit. It has adjustable oil pressure springs, is compact and trouble free over the past 3 years. Contact: Terry Palmer (480) 615-7700
Ray Menard SS/CS (SS/DM & SS/EM) #7386 |
