Old 12-20-2009, 05:48 PM   #1
Rex Thonen
Question lower radiator hose
I need a radiator hose with 1 3/4" ID on both ends with a right angle bend in the middle. I put a new waterpump on my bb camaro, the water pump has a 1 3/4 outlet, the radiator has 1 3/4 inlet. The hose needs to be about 20" long. Any ideas ?
Thanks Rex
Rex Thonen is offline   Reply With Quote
Old 12-20-2009, 06:47 PM   #2
SS Engine Guy
Default Re: lower radiator hose
step up/step down reducers and two different radiator hoses? Stainless steel exhaust step ups/ step downs. Make a 2 piece radiator hose? Use good quality clamps.
SS Engine Guy is offline   Reply With Quote
Old 12-20-2009, 09:21 PM   #3
tj310
Try this
http://www.daycoproducts.com/daycowe...2!OpenDocument
Thanx Trevor
Old 12-21-2009, 10:32 AM   #4
John Dinkel
Liked 265 Times in 69 Posts
Check your local auto parts store and see if they carry universal flexible hoses.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 12-21-2009, 10:59 AM   #5
Geddes
Gates makes "shims" with a flange to reduce hose size. I good parts guy will find them for you.
Geddes is offline   Reply With Quote
Old 12-21-2009, 11:30 AM   #6
Chad Rhodes
-AN adapter on radiator, AN fitting on Water Pump and use an AN hose.
Chad Rhodes 2113 I/SA
Old 12-21-2009, 11:31 AM   #7
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Thanks Rex
Rex, try a 66 Chevelle sbc lower, look and see if its close.......
