Old 12-19-2009, 06:18 PM   #1
Bernie Cunningham
Liked 52 Times in 17 Posts
Default 12 bolt KTRE rear end , f-body '93-'02, complete
This is a KTRE housing with Moser spool and axles, 4.88 pro gears with less than 100 runs. All the factory brackets and a drive shaft yoke(missing 1 u-bolt), powder coated. Large 'Ford type' axle bearings, aluminum rear cover, large 5/8" diameter wheel studs, nuts and spacers. NO BRAKES, it does have SS clips for the brake lines. From the outside of the axle flanges it measures 64.5" and from the axle tube ends it measures 58.75"
Removed from a Stock Eliminator car 7 years ago to go super lightweight MW stuff.
$1490.00
Bernie, bonzaproducts@att.net, 951 684 8113 or cell 909 496 0485
Photobucket
Bernie Cunningham 7053 STK
Bernie Cunningham is offline   Reply With Quote
