Old 12-12-2009, 05:55 PM   #1
KEN BUGAJ
Liked 18 Times in 7 Posts
Angry B&M shifter help
I have a new B&M shifter installed in my car,,,
If I hook the cable up to the trans it works really hard?
If I take it off the trans it works fine,
Anyone got any Idea's what to look for? Thanks, Ken
KEN BUGAJ is offline   Reply With Quote
Old 12-12-2009, 06:38 PM   #2
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Arrow Re: B&M shifter help
Check cable for a rough feeling when disconnected.Very slight,poss causes would be cable pinched or kinked at the factory or shipping.Some oem cbls would do this when I worked at a dealership.Hope this helps.
Kevin
Old 12-12-2009, 07:30 PM   #3
Bob Verwold
Bob Verwold's Avatar
Default Re: B&M shifter help
If your trans shifts ok by hand, I would guess the cable is in a bind (not enough of an easy bend) That's my .02
Bob Verwold is offline   Reply With Quote
Old 12-12-2009, 09:21 PM   #4
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: B&M shifter help
Ken,
Try what Bob said to do.... Make sure the tranny arm shifts easy by hand...If thats OK, check for a kink in the cable.. Try taking it off trans again and adjusting it in each gear to see if that helps ? Make sure you only remove at the eye-let , so the cable is still in the bent position... I think you may find it's in the tranny arm ? Good Luck & Merry Xmas....
Dave Ribeiro 1033 STK
Old 12-19-2009, 09:28 PM   #5
rayfin
the cable is in a bind... been there done that
rayfin is offline   Reply With Quote
