Old 12-11-2009, 09:53 PM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default 327/275/250hp Super Stock Engine
327/275/250hp Super Stock engine.
Currently run in 66 Chevy II SS/H 275hp combo
275hp with Q-Jet
250hp with 4GC
built in 06'
Bowtie block
Manley rods
PSI Springs
BME pistons
Jesel rockers
Jesel beltdrive
Victor "E" manifold
Charlie's pan
TCI rattler
Total seal rings
Deano carb
etc etc
Engine has 9 runs since freshening in '09
Have original build sheet
Have original dyno sheets and current dyno sheet
Complete carb to pan
Call for further details
No talkers or tire kickers. If your really interested call me.
Going to a 283 combo
Ed 512-517-8235 15000.00 until jan 3
Also see racing junk#1749131
25000+ to have one built today
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 12-11-2009, 10:26 PM   #2
283SS
Default Re: 327/275/250hp Super Stock Engine
hello have to ask how do u make 250 hp out of the 275 hp motor do u have a two set of heads that come with the motor????
283SS is offline   Reply With Quote
Old 12-11-2009, 10:51 PM   #3
Ed Carpenter
327/275hp with Q-Jet
327/250hp with 4GC
Ed Carpenter
Old 12-11-2009, 10:57 PM   #4
283SS
yes I now thats but those two motors have defrent heads on them the 250 hp has 1.72 intake and the 275 hp has a 1.94 hmmm
Old 12-11-2009, 11:25 PM   #5
Ed Carpenter
I run a 66 Chevy II with this engine I can run SS/G,H,I with the 275hp combo or I can run in GT by putting a 4GC carb on it. At my weight I can run GT/G or add weight to run GT/H. I have run both combos. There is no changing heads just the carb. I claim the 65 Nova 327/250 for GT. Ed
Ed Carpenter
Old 12-11-2009, 11:29 PM   #6
283SS
ok ty
Old 12-11-2009, 11:31 PM   #7
Ed Carpenter
From NHRA engine blueprint page
NHRA Technical Specifications
For
1965 Chevrolet Motors
ROD
BORE STROKE DISPLACEMENT CYLINDERS LENGTH
3.875 3.250 153 4 5.700
3.438 2.940 164 6 4.720
3.563 3.250 194 6 5.700
3.875 3.250 230 6 5.700
3.875 3.000 283 8 5.700
4.001 3.250 327 8 5.700
4.094 3.766 396 8 6.136
4.313 3.500 409 8 6.010 4/29/2008
Issued: 19 March 1965
Revised: 7-21-78, 1-9-93, 10-15-02, 5-22-03, 10-11-04, 11-10-05 WR, 4-26-06 WR, 5-2-07 WR
H.P. Disp. C.R. Ind. Make Model/Transmission Manifold R.R. Lifter Head cc Notes
90 153 8.50 1-1 Cart YF-3379S/SM, 3402S/AUTO 1.75 H 69.6 1
95 164 8.25 2-1 Roch 7025023/ALL 1.57 H 55.3 2
110 164 9.25 2-1 Roch 7025023/SM, 7025024/PG 1.50 H 48.0 3
120 194 8.50 1-1 Roch 7023105/SM, 7023108/PG 1.75 H 59.4 4
140 164 9.25 4-1 Roch 7025023 FR, 7025226 Rr/ALL 1.50 H 50.2 2
140 230 8.50 1-1 Roch 7025003/SM, 7025000/PG 1.75 H 69.6 4
180 164 8.25 1-1 Cart YH-3692S/SM ONLY 1.50 H 59.8 5
195 283 9.25 1-2 Roch 7024101/SM, 7024110/PG 1.50 H 54.9 6
220 283 9.25 1-4 Roch 7025127/SM, 7025126/PG 3844457 1.50 H 54.9 7,16
250 327 10.50 1-4 Roch 7025127/SM, 7025126/PG 3844457 1.50 H 57.5 8,16
300 327 10.50 1-4 Cart AFB-3721S/SM, 3720S/PG 3844459 1.50 H 57.5 9
325 396 10.00 1-4 Holl R-3139A/SM, R-3140A/PG 3866948 1.70 H 96.4 10,17
340 409 10.00 1-4 Roch 7025123/SM, 7025124/PG 1.75 H 9.2 11
350 327 11.00 1-4 Holl R-3043A/SM ONLY 1.50 H 58.6 12,19
365 327 11.00 1-4 Holl R-2818A/SM ONLY 1.50 M 58.6 13,19
375 327 11.00 FI Roch 7017308/SM ONLY 1.50 M 58.6
375 396 11.00 1-4 Holl R-3310/SM ONLY 3866963 1.70 H 106.9 14,18, 20
Note: The above line spec of 106.9 cc is for the factory iron head, not the 401 al head
375 396 11.00 1-4 Holl R-3310/SM ONLY 3866963 1.70 H 103.3 14,18, 20
Note: The above line spec of 103.3 cc is for the 401 alum replacement head
400 409 11.00 1-4 Cart AFB-3738S/SM ONLY 1.75 M 10.3 15
425 396 11.00 1-4 Holl R-3124A, R-3130A/ALL 069,163,19131359 1.70 M 106.9 14
425 396 11.00 1-4 Holl R-3124A, R-3130A/ALL 069,163,19131359 1.70 M 103.3 14
1 - Carb sizes - 1686/1313 2 – Carb sizes – 1250/1000
3 - Alt carbs - 7025025/ALL Carb sizes - 1250/1000
4 - Carb sizes - 1562/1343 5 – Carb sizes – 1500/1313
6 - Carb sizes - 1437/1093 7 – Carb sizes – 1437x1437/1125x1250
8 - Carbs listed are for Chevelle. Chev II uses 7024255/ALL Corvette uses Carter WCFB-3697S/ALL
Chevrolet uses Carter WCFB-3697S/SM, WCFB-3696S/PG or Roch 7025121/PG
Carb sizes - Roch 1437x1437/1125x1250 Cart 1437x1437/1062x1250
9 - Carb sizes - 1562x1686/1250x1562
10 - Alt carbs - Roch 7025201/SM 7025200/PG or Holl R-3139A/ALL
Carb sizes - Roch 1375x2250/1093xAV Holl 1562x1562/1250x1313
11 - Carb sizes - 1562x1686/1313/1468
12 - Alt carbs - Corvette uses R-2818A/SM ONLY Carb sizes - 1562x1562/1250x1313
13 - Carb sizes - 1562x1562/1250x1313 14 – Carb size – 1686x1686/1375x1437
15 - Carb size-1625x1686/1343x1562 16 – Alt manifold – 922, 858, 459
17 - Manifold listed is for Holley. Roch manifold # 3883948 18 – Alternate manifold – 069,163,19131359
19 – Alternate manifold - 3844461
20 - Carb listed are for Chevelle. All others use R-3130A/SM only
Deck Piston Type
H.P. Disp. Cl Dish/Dome Ht/Vol Valves Cam Lift Springs Gask Head Castings
90 153 .011 Flat w/n 1725/1505 397/397 Outer w/Damp .032
95 164 .0005 Flat 1345/1245 403/403 Outer w/Damp .034
110 164 .0005 Flat 1345/1245 391/391 Outer w/Damp .034 3883863,3878566
120 194 .011 Flat w/n 1725/1505 332/332 Outer Only .032 3864883,329609
140 164 .0005 Flat 1725/1365 391/391 Outer w/Damp .034 3856728
140 230 .011 Flat w/n 1725/1505 332/332 Outer Only .032 3864886,331184,
331183, 3998180
180 164 .0005 Flat 1345/1245 374/374 Outer w/Damp .034
195 283 .014 Flat w/n 1725/1505 399/399 Outer w/Damp .018 896, 520
220 283 .014 Flat w/n 1725/1505 399/399 Outer w/Damp .018 896, 520
250 327 .014 Flat w/n 1945 1505 399/399 Outer w/Damp .018 461,462,041,492,186,291
300 327 .014 Flat w/n 1945/1505 399/399 Outer w/Damp .018 461,462,041,492,186,291
325 396 .005ab Dome .201" 22.04cc 2070/1725 398/398 Outer w/Damp .028 063,206,215,280,290,
390,702,802
340 409 .011 Flat w/slant Note 1 2070/1725 400/412 Outer/Inner .028 3830817
350 327 .002 Dome .120" 5.3cc 2023/1605 447/447 Outer w/Damp .018 Note 2
365 327 .002 Dome .120" 5.3cc 2023/1605 485/485 Outer w/Damp .018 Note 2
375 327 .002 Dome .120" 5.3cc 2023/1605 485/485 Outer w/Damp .018 Note 2
375 396 .005ab Dome .357" 39.50cc 2195/1725 461/500 Outer w/Damp .028 208,858,391,840,291
or Outer/Inner
Note: The above line spec is for the iron heads, not the 401 alum replacement head
375 396 .005ab Dome .357" 39.50cc 2195/1845 461/500 Outer w/Damp .028 401 Alum Head
or Outer/Inner
Note: The above line spec is for the 401 alum replacement head
400 409 .011 Flat w/slant Note 1 2195/1725 557/557 Outer w/Damp .028 3852583
425 396 .005ab Dome .357" 39.50cc 2195/1725 497/503 Outer w/Damp .028 208,858,391,840,291
or Outer/Inner
425 396 .005ab Dome .357" 39.50cc 2195/1845 497/503 Outer w/Damp .028 410 Al Head
or Outer/Inner
Note 1 - Block volume = 64.6cc Note 2–Head s= 820,461,462,186,414,041,492,291
Ed Carpenter
Old 12-12-2009, 01:26 AM   #8
Tom Moock
Liked 10 Times in 6 Posts
283SS, 1964 327-250hp. small intake valve 283 head. 1965 327-250hp large intake valve 327 head. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 12-15-2009, 08:43 PM   #9
Jim Hanig
Liked 99 Times in 49 Posts
The big valve motor rated at 270 the small valve rated at 258. Jim Hanig
Old 12-16-2009, 03:35 AM   #10
Ed Carpenter
Cool Re: 327/275/250hp Super Stock Engine
So I don't get asked this question anymore the engine made 556hp on the dyno with the 4GC carb. The motor was not dynoed with the Q-Jet on it. Obviously it makes more power with the Q-Jet. Thanks. Ed
Ed Carpenter
