Old 12-06-2009, 03:25 PM   #1
Kris
Liked 2 Times in 2 Posts
Default 451 Big Block Mopar
Indy top end (heads, intake, roller rockers, push rods and valve covers), magnum block w/ aluminum main caps 55 over, steel crank, eagle rods w/ L-19 bolts, wiseco flat tops, Comp roller cam, Milodon gear drive, external oiling system, new rings and gasket set, needs bearings to be put together, several pans, flexplates and flywheels. Take it all, someone close would be nice, shipping could pose a problem. Also, a set of coated Super Comp headers to add into the mix with everything too, not for this motor but a nice set. They are part #5209 to see applications. $740 brand new, never been used. Price everything out and see what it comes up to I have alot of real nice parts here.
$4000
Thanks for looking
Kris is offline   Reply With Quote
Old 01-05-2010, 05:33 PM   #2
jafr
Default Re: 451 Big Block Mopar
Where are you located? you can email me at jsdavisracing@netzero.com
jafr is offline   Reply With Quote
