Old 11-29-2009, 08:35 PM   #1
Jeff Teuton
Liked 325 Times in 50 Posts
Default 1968 Hemi Cuda Clone
440 + .060 CP Pistons,Short Deck, MCH Stage V heads, T & D Rockers, Manley Rods, Comp Roller, Wilson Manifold, Holley & AVS carbs,Pro Trans w/brake, shield, A1 Converter, Air shift, MSD, BG Pump, Stainless lines, New complete wiring, Hoosier, Moser Dana 60 (several ratios), 35 spline, gun drilled, lightened, studs, Monocque wheels, Aerospace brakes, two d. shafts, 1350 joints,Strange Double adj frt shocks, rear Cal Trac complete, data recorder, recording tach, new seats & covers,full cage (2 yrs) w/swingout, Custom pan & oiling system, ss step headers w/merge collectors, alm radiator, Moroso w/pump, runs GT/CA @ 350 hp, runs 9.70's, Also 383 Short Block w/same equip (all will fit), has different converter for 383,(new in car never run). 383 also .060, stroked crank, comp roller, Runs GT/EA @ 300 hp, 383 currently in car, All motor/trans etc less than one year old. Much more, best stuff available. Has only been run once as GT/EA, ran most of season as GT/CA. Search under Sid Bonnecarrere photos in Auto Imagry or DRC. Absolutely ready to race. complete dyno sheets and build records $38,000 for all. Jeff Teuton jefft@southlanddodge.com Business no. 888-876-1817 or cell 985-804-6161
Jeff Teuton 4022 STK
