Old 11-25-2009, 09:14 PM   #1
Jeremy K
Question Panhard bar for 3rd gen. Camaro
I see that adjustable panhard bars are made with polyurethane bushings or with rod-ends. First, are the ones with rod-ends legal in stock eliminator? Second, if legal, is there any advantage to having a panhard bar with rod-ends for drag racing? Thanks.
Jeremy K is offline   Reply With Quote
Old 11-26-2009, 10:56 AM   #2
Brian VP
Liked 8 Times in 1 Post
Default Re: Panhard bar for 3rd gen. Camaro
Yes they are legal and the only reason the rod ends are beneficial is for a less friction in movement, but it is a very small advantage.
Brian Van Poppel
Brian Van Poppel 1682 SS
Brian VP is offline   Reply With Quote
Old 11-26-2009, 01:37 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
another advantage allows fine tuning the tire centering in the wheel well opening. Sometimes just being able to move the axle assemble 1/4" side to side can help with tire clearance.
Larry Woodfin 471W
Old 11-26-2009, 06:04 PM   #4
Jeremy K
Thanks for the responses, that answered my question. Dragsinger, I was looking to get an adjustable panhard bar for just what you said, help center the tires in the openings. Since they are available with poly. bushings or rod ends, I was just looking for advantages of the bar with rod ends.
